Testing and Results
We followed our standard case testing methodology, as detailed in our
previous heatsink and case testing article, and fitted the usual set of hardware into the case, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
Motherboard: MSI P6N SLI Platinum
RAM: 2x 512MB Corsair XMS2-667
Hard Drive: 1x 250GB Western Digital WD2500 7,200RPM
Heatsink: Asus Silent Square Pro
Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high-end hardware, the equipment we use is specifically selected to kick out the maximum amount of heat inside the case. With a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit.
In our experience, our CPU stress test is a good way of indicating a case's ability to exhaust hot air and the GPU stress test is a better indicator of a case's intake ability. This is because the GPU is generally further from the exhaust fan and so its operating temperatures rely more on case airflow than exhaust.
Following feedback from the
bit-tech Community, we've changed the way we display case thermal performance. We've removed ambient and case temperatures from our graphs and just left the more important values of GPU and CPU Delta T – the differences between the ambient temperatures and the component's temperature. We feel this provides a much clearer representation of a case's cooling ability where it counts, as well as producing results that are much easier to digest.
SilverStone FT01
Thermaltake Spedo
Cooler Master HAF 932
Cooler Master Sniper
Antec Nine Hundred Two (Full Speed)
Antec P193 (High Speed)
Lian Li Tyr PC-X2000
Lian Li PC-P50
Akasa Infiniti ZOR
Antec Nine Hundred Two (Low Speed)
Antec P193 (Low Speed)
Akasa Omega
Cooler Master ATCS 840
Lancool K7 Metal Boned
°C
P193 (High Speed)
Thermaltake Spedo
P193 (Low Speed)
Lian Li PC-P50
Akasa Omega
SilverStone FT01
Akasa Infiniti ZOR
°C
Thermaltake Spedo
Lian Li PC-P50
SilverStone FT01
P193 (High Speed)
P193 (Low Speed)
Akasa Infiniti ZOR
Akasa Omega
°C
